2016-05-04 2:37 AM
Hi, i would like to increase the range of the VL6180X but i don't know which register i have to modify. I see the code in the RangingAndALS_NucleoXXX sample but i don't understand how the VL6180X register have been modified in order to increase the measuring range.
Thanks #vl6180x #range2016-06-10 10:22 AM
I am having the same problem...did you figure it out??2016-07-16 3:05 AM
not yet
2018-05-17 12:52 AM
I am having the same problem, did you solve it? What configuration parameters you need to modify?
