Visitor II
May 20, 2024
VL6180X laser compliance documents
  • May 20, 2024
  • 1 reply
  • 938 views
We are using the VL6180X in a IVD product and need laser test certificate documents to show the range sensor is class 1 and safe for the user. Can you send me a test reports for this part? I see a CDRH report posted for VL53L1, but couldn't find it for the VL6180.
Thanks,
Andrew
Best answer by Anne BIGOT
The report was sent directly to the customer.
1 reply
Anne BIGOT
Anne BIGOTBest answer
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised. ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
