2021-03-01 10:34 PM
On my board, I have two supply options within the permissible range of this sensor (2.6~3.5V) i.e. 2.9V & 3.3V. Will there be any switching noise coupling to the power supply due to the ranging operation of the sensor? Are there any recommendations to mitigate noise coupling?
2021-08-19 12:07 PM
I don't know how the power is generated - only that it is and there are no issues.
The sensor creates it's own voltages internally from what you give it.
I've not heard of any complaints about noise coupling.
2021-08-19 12:07 PM
