VL53L1x - gesture recognition
adi-mistrzu
Posted on April 26, 2018 at 08:11
Anyone know how to config VL53L1x to gesture recognition?
In datasheet is information about support 1D
gesture recognition, but nowere I cannot find information how to config it to gesture recognition and how to use it.
I check your API for this sensor, but there no code for gesture recognition.
Anyone know how to do that?
Best regards
#recognition #api #gesture #vl51l1x
1 REPLY 1
John E KVAM
Posted on May 02, 2018 at 00:39
There is no 'gesture recognition' mode by itself. The concept relies on simply ranging and looking for a changing distance result. It's up to the use to interpret the distance measurements and decide what the gesture is.
One way is to range with a threshold. Your CPU can be asleep. When a hand comes close, the sensor will wake your processor and you can start looking at the data. Interpret the gesture based on what the distance and signal strength data is telling you.
Our community relies on fruitful exchanges and good quality content. You can thank and reward helpful and positive contributions by marking them as 'Accept as Solution'. When marking a solution, make sure it answers your original question or issue that you raised.
ST Employees that act as moderators have the right to accept the solution, judging by their expertise. This helps other community members identify useful discussions and refrain from raising the same question. If you notice any false behavior or abuse of the action, do not hesitate to 'Report Inappropriate Content'
