Using 'libiio' to read Accelerometer data from the IMU
Sharat_Rao
We want to use iio buffers to read accelerometer data. I tried the following, but it did not work.
root@FAFUSION:/sys/bus/iio/devices/iio:device2# ls buffer current_timestamp_clock events in_accel_scale_available in_accel_y_raw mount_matrix of_node sampling_frequency scan_elements uevent buffer0 dev in_accel_scale in_accel_x_raw in_accel_z_raw name power sampling_frequency_available subsystem waiting_for_supplier root@FAFUSION:/sys/bus/iio/devices/iio:device2# cat name ism330dhcx_accel root@FAFUSION:/sys/bus/iio/devices/iio:device2# root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_accel_x_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_accel_y_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_accel_z_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_accel_x_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_accel_y_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_accel_z_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > scan_elements/in_timestamp_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/in_timestamp_en root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 833 > sampling_frequency root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer/enable root@FAFUSION:/sys/bus/iio/devices/iio:device2# echo 1 > buffer0/enable root@FAFUSION:/sys/bus/iio/devices/iio:device2# cat buffer0/* 0 in 1 1 0 le:s16/16>>0 1 1 le:s16/16>>0 1 2 le:s16/16>>0 1 3 le:s64/64>>0 1024 1 root@FAFUSION:/sys/bus/iio/devices/iio:device2# iio_readdev ism330dhcx_accel accel_x accel_y accel_z timestamp WARNING: High-speed mode not enabled Unable to refill buffer: Connection timed out (110)
View more
What is the correct way of using 'libiio' to read the accelerometer data
Hi @Federica Bossi ,
The link you have provided has drivers which we are already using as part of the Mickledore distribution but it does not provide any user-space application examples to read the sensor using IIO.
Anyway, we have been able to write our own application that pulls the data out of the FIFO at a good rate.
2 REPLIES 2
Federica Bossi
Hi @Sharat_Rao ,
Have you already looked at our official drivers and examples on Github?
Hope this helps!
