Using IIS3DHHC as Inclinometer
AV B.1
I am using STM32F401VE with IIS3DHHC accelerometer sensor. I wanted to use the accelerometer as inclinometer. Apparently some documents are available with the mathematical formula to convert the accelerometer into inclinometer. However, I was wondering if there are some libraries which are available for the calibration of the inclinometer and implementation of Kalman filter.
I am wondering if the Kalman filter is necessary for this sensor. Please help
Akhil.
AG.8
Hi @AV B.1​ , Kalman filter is always a good solution from my point of view.
There is the MotionTL library in the X-CUBE-MEMS1 package that enables the tilt measurement
https://www.st.com/resource/en/user_manual/um2277-getting-started-with-motiontl-tilt-measurement-library-in-xcubemems1-expansion-for-stm32cube-stmicroelectronics.pdf
For a broad application of the Kalman filter, there is also this interesting project, but I don't know the status of its maturity
https://www.st.com/en/wireless-connectivity/b-uwb-mek1.html
AG
