2020-06-28 09:52 PM
I am trying to update the firmware on my Sensor Tile Box (STEVAL-MKSBOX1V1). The current version on my Sensor Tile Box is 3.3.5.
On startup, The IOS app indicates that the new firmware V3.41 is available for the box. However, trying to update to this version fails as the IOS app shows the progress blue line going almost to the end but it stops after 726400 of 726532 bytes and indicates error sending data.
When this happens, the sensor tile becomes nonfunctional and the only way to make it functional again is to remove the battery and reconnect again.
I have tried multiple times to update with no success.
2020-07-16 07:08 AM
Hi @KJala , you could try to update the new firmware not via FOTA but via USB, entering the device in DFU mode. You can find the details in the post at THIS link. Regards
