Temperature reading from LSM9DS1
PRebo.1
When reading the temperature from a LSM9DS1, what's the unit that is used ? Cº ?
Eleon BORLINI
Hi @PRebo.1​ ,
The measurement unit is °C, but you have to convert the 16bit value into °C according to the 16 LSB/°C, as described in the datasheet, p. 14.
I suggest you to check also the C drivers on Github for the LSM9DS1, in particular the lsm9ds1_reg.c file and the LSB-to-degC conversion formula:
float_t lsm9ds1_from_lsb_to_celsius(int16_t lsb)
  return (((float_t)lsb / 16.0f) + 25.0f);
Please let me know if this answers your question.
-Eleon
