STEVAL-BFA001V1B wrong cable description
‎2020-07-10 9:26 AM
I wanted to try the STEVAL-IDP005V1 from STEVAL-BFA001V1B,
I followed the description given in UM2438
and nothing worked,
Finally I realized that the cable description is wrong (or may be I've got a bad cable),
the ground is on white, not on blue wire
‎2020-07-14 9:03 PM
your right.
White is GND. The document description is different than actual wiring.
Do you feel lot of heat generated around Accelerometer?
‎2020-07-15 11:14 PM
yes, I feel heat too, a little warm, but it is normal, I think it is coming from MCU on other side, BR
‎2025-03-12 10:25 AM
Are you sure about this? I have
STEVAL-BFA001V1B and it has 4 wires for io link as per the user manual
blue is GND and grey is +VCC (18-24V)
I tried this and I was able to get the mcu and UART to send me the starting message with some details.
‎2025-03-12 11:45 AM
How did you verify this? is it available in the schematics?
‎2025-03-13 3:04 AM
You got a bad cable documentation is correct and it is supposed to be the same but you might have faulty cable , wired incorrectly
