Source code for ST.COM's X-CUBE-MEMS1 available?
‎2020-01-05 8:50 PM
Is the source code for ST.COM's X-CUBE-MEMS1available? I am using an STM32L412. And when I try to include the STM32 pre-compiled library into my project I get errors. I am thinking the processor I am using is not compatible with the libraries. So I'd like to try using the source code instead.
-thanks
‎2020-01-06 12:53 AM
The libraries are compatible with STM32L412 or any device with Cortex-M4.
The source code of the libraries are not public.
What error did you get and which IDE do you use?
‎2020-01-06 5:13 AM
Hi @Miroslav BATEK​
My code was compiling before adding X-CUBE-MEMS1 libraries. After adding the libraries, there were several very long error messages that appeared to be truncated. I assumed they were because the libraries were not compatible with the processor. But it may be I have added the libraries incorrectly. I will post the response I get once I get to that computer.
-again, thank you for your help.
‎2020-01-06 7:12 AM
Here are the 2 lines of errors I see after adding the X-CUBE-MEMS1 MC and EC libraries and the associated header files...
c:/program files (x86)/atollic/truestudio for stm32 9.3.0/armtools/bin/../lib/gcc/arm-atollic-eabi/6.3.1/../../../../arm-atollic-eabi/bin/ld.exe: error: LSM9DS1 Driver.elf uses VFP register arguments, ../Middlewares/STM32_Motion_Library/Lib\MotionEC_CM4F_wc32_ot.a(motion_ec.o) does not
c:/program files (x86)/atollic/truestudio for stm32 9.3.0/armtools/bin/../lib/gcc/arm-atollic-eabi/6.3.1/../../../../arm-atollic-eabi/bin/ld.exe: failed to merge target specific data of file ../Middlewares/STM32_Motion_Library/Lib\MotionEC_CM4F_wc32_ot.a(motion_ec.o)
‎2020-01-06 7:28 AM
Please check the project settings in C Compiler - target - Floating point.
These should be settings something like "Mixed ..." not Hardware Implementation.
The libraries are compiled with -mfloat-abi=softfp option .
‎2020-01-06 7:33 AM
So, the error is not truncated. I believe it is saying my code is setup to use VFP registers and the MotionEC code (library) is not. I'm assuming VFP controls the way the ARM registers are used. However, I am not sure what I am looking for in the code. As there are many defines with VFP in the define names (for example: "_TARGET_FPU_VFP", "_ARM_PCS_VFP", "__VFP_FP__", ect).
‎2020-01-06 7:44 AM
Go to project properties and try to find the settings there,
I don't have Attolic TrueStudio but in STM32CubeIDE it looks like in the attached screenshot.
‎2020-01-06 8:27 AM
Digging further, (according to this stack exchange question / answer: https://stackoverflow.com/questions/9753749/arm-compilation-error-vfp-registered-used-by-executable-not-object-file) this may be a "hard-float" verses "soft-float" problem.
‎2020-01-06 9:33 AM
Trying something: Under Properties=>C/C++ Build=>Settings=>Tool Settings=>C Compiler=>Target=>Floating point change from "Hardware Implementation" to "Mix HW/SW implementation". Also did the same under Linker (Under Properties=>C/C++ Build=>Settings=>Tool Settings=>C Linker=>Target=>Floating point change from "Hardware Implementation" to "Mix HW/SW implementation"). Now the project compiles! But I am not sure if the code is working as expected yet.
‎2020-01-06 11:37 AM
I'm sorry @Miroslav BATEK​ . I didn't realize you had posted 2 answers while I was entering more follow up information. I just refreshed my web page and now see where you were directing me toward the correct answer way before I had stumbled though them.
Thanks again!
