Question from Predictive Maintenance Webinar 29th of April: What's the difference betw. a vibration sensor and an accelerometer?
Pasi MYLLYMAKI
Vladimir  JANOUSEK
We call vibration sensors accelerometer products with higher measurement bandwidth like IIS3DWB, but it is not only this. The vibration sensing applications also require higher temperature range +105degrees, temperature stability so in general KPIs we were highlighting in the webinar (low noise, flat and wide frequency response, stable sensitivity over temperature, high out of the band signal attenuation)
