Question from Predictive Maintenance Webinar 29th of April: In the webinar you did not mention much about documentation. What is avaialble specifically for the vibration sensor and STWIN ?
Pasi MYLLYMAKI
Vladimir  JANOUSEK
Yes, there are many documents available for our products and boards. For the IIS3DWB vibration specifically, you will find at our website of course the datasheet, which includes even more information than we described in this webinar. Then I would recommend to read through the vibration sensor Application Note AN5444, which goes in details about all sensor register configuration options, FIFO detailed programming capabilities, handling of interrupts and so on. This application note is important complementary document to the datasheet. For STWIN board, there are many documents online including the schematic, BOM and gerber files. Also you find there dedicated board user manuals and one of them is specifically focused on high speed data logging we introduced in our webinar briefly.
