Question from Predictive Maintenance Webinar 29th of April: Can we use a wake up threshold using the microphone?
Pasi MYLLYMAKI
Vladimir  JANOUSEK
There is no programmable configuration register in the digital MEMS microphone for that, but when the microphone signal is read with STM32, you can add / implement wake-up threshold in SW code. Some digital MEMS microphones from ST have so called low power mode which could be used in a way for audio wake-up purposes.
