Problem with Heading Calculation
gtk
Visitor
I'm using ST MotionFX v2.7.1 and have encountered an issue with heading calculation.
I'm following the sample code from the document:
um2220-getting-started-with-motionfx-sensor-fusion-library-in-xcubemems1-expansion-for-stm32cube-stmicroelectronics
#define STATE_SIZE (size_t)(2450)
static uint8_t mfxstate[STATE_SIZE];
MFX_knobs_t iKnobs;
MFX_input_t data_in_scale;
void main() {
    /* Sensor Fusion API initialization function */
    MotionFX_initialize((MFXState_t *)mfxstate);
    /* Modify knobs settings & set the knobs */
    MotionFX_getKnobs((MFXState_t *)mfxstate, &iKnobs);
    iKnobs.LMode = 2;
    iKnobs.modx = 1;
    iKnobs.output_type = 1;
    iKnobs.start_automatic_gbias_calculation = 1;
    //orientation
    MotionFX_setKnobs((MFXState_t *)mfxstate, &iKnobs);
    MotionFX_enable_6X((MFXState_t *)mfxstate, MFX_ENGINE_DISABLE);
    MotionFX_enable_9X((MFXState_t *)mfxstate, MFX_ENGINE_DISABLE);
    /* Enable 9-axis sensor fusion */
    MotionFX_enable_9X((MFXState_t *)mfxstate, MFX_ENGINE_ENABLE);
    // init last_time
    clock_gettime(CLOCK_MONOTONIC, &last_time);
    get_sensor_data_scale(&data_in_scale);
    MFX_input_t sensor_in;
    MFX_output_t sensor_out;
    for(int i =0; i< 9999999999; i++)
        get_sensor_data(&sensor_in);
        float delta_time = get_delta_time();
        MotionFX_propagate((MFXState_t *)mfxstate, &sensor_out, &sensor_in, &delta_time);
        MotionFX_update((MFXState_t *)mfxstate, &sensor_out, &sensor_in, &delta_time, NULL);
        printf("Heading: %f\n", sensor_out.heading);
When I run the code, the heading value is incorrect. However, if I re-run MotionFX_initialize, the heading calculation becomes correct.
MFX_knobs_t iKnobs;
void main() {
        iKnobs.LMode = 2;
        iKnobs.modx = 1;
        //orientation
        // init last_time
Does anyone know why this happens? Any insights would be greatly appreciated! Let me know if you need more details.
0 REPLIES 0
