2019-07-17 2:42 AM
Hello, this should be a basic question but I am pretty new in this field. What are the core difference between a 3 and a 4 wir SPIe configuration for LSM6DSOX? Apart from electrical connection, is there any difference in Firmware design, capabilities etc ... ?
2019-07-17 2:48 AM
The 4th wire is chip select. De-asserting CS is a good way to abort a run-stray communication.
2019-07-17 5:53 AM
@Uwe Bonnes What do you mean by "aborting a run-stray communication" ?
2019-07-19 3:28 AM
"Run astray communication" in the sense that things do not happen as you expect it. With CS going high and the low again, the device starts from a known state in the SPI communication, like an SPI communication reset.
