2024-04-29 12:50 AM
Hi everyone,
I'm working on setting up an SPI connection between the LSM6DS0x and an MCU. I'd like to clarify the pin configuration for a full-fledged SPI setup to ensure I'm getting the most accurate data.
Specifically, I have the following questions:
Any additional tips or recommendations for achieving the most accurate data transfer over SPI would be greatly appreciated.
Thanks in advance for your help!
2024-05-02 1:07 AM
Hi @dhruvit ,
Here you can find examples on LSM6DSOX.
I suggest to follow MCU pin configuration of _prj_MKI109V3.ioc that in the example use by default SPI communication with LSM6DSOX sensor.
Regarding SDx (Serial Data master) and SCx (Serial Clock master), both pins are related to I2C so they can be linked to GND (as described in the datasheet.
