LPS22HB LC_EN (low current mode enable)
tve
Is there any application note or other information available about the LPS22HB's low current mode, as enabled by LC_EN in RES_CONF register? Other than reducing power consumption, what does it do and specifically, how does it affect performance?
Federica Bossi
Hi @tve ,
In low current, all filtering and averaging that is computationally relevant in terms of current is ignored. This certainly increases the accuracy of the output data.
Thanks for the reply, I assume you meant "decreases the accuracy"?
