LSM6DSO inclinometer
gabriel.arnautu
I was playing around with Unico and I saw it has an inclinometer function. Is the code for that window available:? I tried an implementation with Kalman filter, but the Unico seems to show the angles much better.
Gabriel
4 REPLIES 4
Eleon BORLINI
Hi Gabriel, welcome back. Unfortunately the source code for Unico is not available... You could however manage to implement the inclinometer function using the Tilt detection using the MotionTL middleware library of the X-CUBE-MEMS1 (here). Regards
gabriel.arnautu
Hi Eleon,
Unico uses the same middleware?
Gabriel
Eleon BORLINI
​yes Gabriel, almost similar. Sorry for my question, but are you interested in the algorithm results or in the graphical rendering of the inclinometer measure? Are you finding some lack of accuracy in using that libraries? Regards
gabriel.arnautu
Hi Eleon,
I am intrested in the algorithm, not the GUI. Tomorrow I will try to use MotionTL and see how it goes. Actually, I need it in Python, but if I have it in C I can just convert it.
