2018-09-21 04:29 PM
We have an LSM6DSL sensor working in fifo mode. We are running it at 833 Hz but with the measured data, we are getting ~ 819 Hz. I am trying to investigate what the cause is. Can you tell me how accurate the internal clock is? If set properly, shall I expect exact 833 samples/ second? or is it okay to see some drift?
2018-09-23 07:20 AM
Yes, it is normal. There can be some inaccuracy. Unfortunately the exact information about the internal clock accuracy cannot be shared on the forum.
2018-09-24 11:01 AM
I see. How can I get more information about the clock then?
2018-09-26 02:11 AM
You can try to send a request for the information through OLS (https://my.st.com/ols).
