2024-01-18 11:35 PM
Please, for a pressure measurement in an environment of dust and humidity, which sensor between the 2 you recommend as well as what is the IP protection rating of each sensor.
Thanks in advance
2024-01-19 12:12 AM
Hi @ljm ,
At the moment our best candidate is LPS27HW, but I can also suggest LPS28DFW
If it is not written on the datasheet, there is no IP certification.
2024-01-19 12:12 AM
Hi @ljm ,
