LIS3DSH
‎2019-07-05 6:13 AM
I interfaced LIS3DSH with Nordic controller(PCA10040). I am facing following issues:
- Data is repeating in Y-Axis.
- Data is coming 0 for 3 times continously in I2C read buffer.
- In X-axis same data is coming for 4 seconds data like 1964
please suggest any ways to solve this problems.
for your reference I am attaching data
Thanks & Regards,
Chaitanya.
‎2019-07-05 7:27 AM
Hi @chaitanya chippada​ , a few questions to understand the issue: are you correctly converting raw data into 16-bit two's complement data? Are you reading data in continuous mode and at which ODR? Vdd and VddIO have the same value? Regards
‎2019-07-07 10:22 PM
Hi Eleon,
Thanks for your reply,
A. Yes, we are converting correctly, as some other data points is correct, following is the function we are using for converting raw value to g value.
int16_t two_compl_to_int16(uint16_t two_compl_value)
int16_t int16_value = 0;
/* conversion */
if (two_compl_value > 32768) {
int16_value = (int16_t)(-(((~two_compl_value) & (uint16_t)(0xFFFF)) + (uint16_t)(1)));
} else {
int16_value = (int16_t)(two_compl_value);
return int16_value;
A. we are reading data from sensor continously (stream mode)by giving required delay, for your reference I am attaching configured parameters, please suggest if any other settings required.
ret_code_t err = NRF_SUCCESS;
uint8_t reg[2] = {0x00};
reg[0] = MEMS_SENSOR_CTRL_REG4_ADDR;
reg[1] |= DATARATE_1600;
err = writeTolis3dsh(®[0], sizeof(reg));
APP_ERROR_CHECK(err);
reg[1] |= XYZ_ENABLE;
reg[0] = MEMS_SENSOR_CTRL_REG3_ADDR;
reg[1] = 0x00;
reg[0] = MEMS_SENSOR_CTRL_REG5_ADDR;
reg[1] |= FILTER_BW_800;
reg[1] |= FULLSCALE_2;
reg[1] |= (SELFTEST_NORMAL | SERIALINTERFACE_4WIRE);
reg[0] = MEMS_SENSOR_CTRL_REG6_ADDR;
reg[1] |= (FIFO_ENABLE | AUTO_ADDRESS_INCREMENT);
reg[0] = MEMS_SENSOR_FIFO_CTRL_ADDR;
//reg[1] |= FIFO_STREAM_MODE;
reg[1] = FIFO_STREAM_MODE;//0x40;//0x54;
A. Yes, Vdd & VddIO is same value 3.3 V
Thanks for your quick support,
chaitanya
‎2019-07-09 2:37 AM
A. Yes we are correctly converting raw data
A. We are reading in stream mode with 1.6KHz ODR
VDD and Vddio have same value 3.3volts
chaitanya
‎2019-07-24 7:14 AM
Do you have the same issue also at lower ODR? Regards
