2015-06-09 6:36 AM
I am using LIS3DSH accelerometer, sampling rate 100HZ scale = +-2G. What I see is from time to time is noise what is coming from one of the axis, I tried to add more decoupling caps, thy to change internal filter settings nothing helps.Please see attached for your reference.Thank you for the help.Regards,Andrew
