2012-07-31 11:12 AM
We use LIS3DH at 10Hz, with FIFO, low power mode, I2C for communication. We measure current at we get:
- at 3.6V supply, 160uA- at 3.0V supply, 100uA- at 2.3V supply 60uAThe datasheet claims 6uA, what might we be doing wrong? #lis3dh2015-11-24 10:55 PM
I've tried connecting SA0 to Vcc, but I get a negative voltage over the 100R shunt (-3.6mV). With a 1K shunt, I get -36mV. How could this be the case?
Thanks for the help in advance.2016-09-16 6:48 AM
Hi Support team,
Since there is an internal pull-up on this pin, it could be left floating/disconnected and assume this solution is going to be reliable? or it must be tied to VCC?Thanks in advance,2016-09-19 6:24 AM
I am going to answer my own question. The answer is not. If this pin is left disconnected the ''pull-up'' is not strong enough and oscillates under certain conditions.
