2026-01-06 1:17 AM
Hi,everyone.
I measured the power consumption of LIS2MDLTR on the same board in power-down mode.
and found that the LIS2MDL chip on STEVAL-MKI217V1(from mouser) consumes less power than the LIS2MDL purchased separately from mouser.
We have some question and need your help.
2026-01-08 7:20 AM
Hi @young ,
The typical current consumption in PD mode is 1.5uA, as written in the datasheet.
How much difference did you measure between the two parts? It could be part-part variability.
2026-01-08 7:20 AM
Hi @young ,
2026-01-13 5:14 PM
Hi,@Federica Bossi,
The consumption in PD mode that I measured is 70 ~ 80uA.
The power consumption of the component deviates significantly from the typical consumption.
2026-01-15 11:36 PM
Hi @young ,
How are you testing the LIS2MDL? There may be an error in your board design that is causing extra power consumption.
