2023-10-10 12:29 AM
2023-10-11 01:04 AM
Hi @THSW ,
Welcome to ST Community!
Have a look at our driver example on Github, I think it could help you.
If this solves your problem, please mark my answer as "Best Answer" by clicking on the "Accept as Solution" button, this can be helpful for Community users to find this solution faster 🙂
2023-10-11 07:37 PM
我曾尝试过,fifo中断(int1 int2)可以,但是唤醒(int1 int2)仍然不行,还是说fifo(int1)和唤醒中断(int2)一起用有冲突
2023-10-11 10:15 PM
please help,thanks
2023-10-11 11:46 PM
我配置过WAKE_UP_DUR,WAKE_UP_DUR,SLOPE_EN,INTERRUPTS_EN,MD2_CFG,但是我从这些寄存器中读出来的值都是0,这是传感器的问题吗,其他的寄存器的值都是正常的
