2024-07-18 4:19 AM
HELLO,Can someone tell me the time accuracy of the output rate of II3DHHC?
Takenari otawa
2024-07-22 2:42 AM
Hi @totaw.1 ,
We don't provide a minimum and maximum value but consider that, from characterization data, and thus on a limited number of parts, we have an ODR accuracy of +/- 15% for IIS3DHHC.
2024-07-18 6:00 AM
It's not specified and not guaranteed, but you can generally expect it to be at least 1 ksps.
2024-07-18 6:57 AM
Hi TDK
Thank you for your reply.
The ODR is 1.1k, but is it correct that there is no documentation or data showing
the maximum and minimum values?
Takenari otawa
2024-07-22 2:42 AM
Hi @totaw.1 ,
2024-07-22 3:01 AM
Thank you very much, it is very helpful!
Thanks.
T.Otawa.
