IIS3DHHC ODR clock accuracy
totaw.1
HELLO,Can someone tell me the time accuracy of the output rate of II3DHHC?
Takenari otawa
Federica Bossi
Hi @totaw.1 ,
We don't provide a minimum and maximum value but consider that, from characterization data, and thus on a limited number of parts, we have an ODR accuracy of +/- 15% for IIS3DHHC.
4 REPLIES 4
It's not specified and not guaranteed, but you can generally expect it to be at least 1 ksps.
totaw.1
Hi TDK
Thank you for your reply.
The ODR is 1.1k, but is it correct that there is no documentation or data showing
the maximum and minimum values?
Takenari otawa
Federica Bossi
Hi @totaw.1 ,
totaw.1
Thank you very much, it is very helpful!
Thanks.
T.Otawa.
