2022-11-27 9:37 PM
2022-11-28 12:58 AM
Hi @wzhen.2 ,
ASM330LHB is just the ASM330LHH ASIL-B part number. You can then use C drivers on Github --> asm330lhh_STdC.
If otherwise you need also other sample code, you might refer to the device software page (LINK) or to this partner page for the ASIL-B drivers.
-Eleon
2022-11-28 12:58 AM
Hi @wzhen.2 ,
-Eleon
2022-11-28 5:43 PM
Hi Eleon
I have download the asm330lhh drvier package from above link last day, and i checked the register map with asm330LHB, it is same. Thank you for your quick response,
-zhenwei
