I guys, I was looking at the VL53L1X to detec water level in a manhole but it says the field of view is 15°-27°. Being in a manhole, this is way to wide. Any suggestions?
2020-08-24 11:36 AM
The device I am developping on is on top of the manhole at 3-4 meters high and I need a 2-5 mm precision or so. I look forward for an idea. Looking at basic laser meters to take measurements, they all are capable of doing what I am looking for, but can't find what technology/sensor they use to make it happen... Any insight would be appreciated.
Thanks!
2020-08-24 12:05 PM
The sensor has 16x16 SPADs internally, see data sheet. Its possible to use parts of that downto 4x4. This will narrow the FoV.
2020-09-03 8:17 AM
Hi @PGagn.1 , did you solved you issue?
-Eleon
