¿How to switch on sensor?
NMart.1
Hello
I am working with  STEVAL-MKSBOX1V1 and FP-SNS-ALLMEMS2. I upgrade the firmware with CubeProgrammer (using the option of "run after programming") and it works. But I want to know how to switch on the sensor if I don't select this option while programming.
For exampe, if baterry charge ends, it will shut down. If I connect it to power supply, it should switch on again. (With power,user or boot bottons it doesnt switch on)
Eleon BORLINI
Hi @Nicolás Martinez​ , let me check if I correctly understand your question: you want to manage the power ON and power OFF of the single sensors via firmware, right? Or of the entire SensorTile.box? In this second case, I suggest you to use the USER button and related MCU pin to temporary close the Vdd-GND path and to reset the board components.
