How to set up LSM303AGR for accelerometer measurements?
MTole
The register CTRL_REG1_A is set with 0x57 and CTRL_REG4_A with 0x80.
All output Accelerometer registers give the same value 0xC0.
What is missing for correct accelerometer measurements?
Miroslav BATEK
You can use the platform independent drivers available in GitHub:
https://github.com/STMicroelectronics/STMems_Standard_C_drivers/tree/master/lsm303agr_STdC
There is also example for basic sensor setup and data reading.
For more details please read application note AN4825:
https://www.st.com/content/ccc/resource/technical/document/application_note/group0/6d/cd/b8/e0/44/98/4e/81/DM00265383/files/DM00265383.pdf/jcr:content/translations/en.DM00265383.pdf
