2018-07-13 07:36 AM
Hi all,
i have a problem to read the FIFO value of x, y and z accelerations.how should i set the parameter of the register?
When i send a command to read 'FIFO_DATA_OUT_L' and 'FIFO_DATA_OUT_H' how can i recognize if the data read is the acceleration X, Y or Z?
thank you very much.
2018-07-16 02:14 AM
Please read Application node
, FIFO is described in chapter 8.
