How to connect more LSM303AH on one SPI BUS?
PUnze.1720
We are affraid when one device has CS signal down, other devices will be set to I2C there can be conflict on the SPI BUS. Is it possible connect more devices as eclosed schematic?
10 REPLIES 10
PUnze.1720
Regarding of PCB design it was very complicated to find solution. Now, after replacing of one bad device on the bus everything works well as should and level on SCK is 1,8V. Thank you for your support.
