STEVAL-PROTEUS1 to monitor temp and vibration on a spindle
Cornwlp
I am trying to use a proteus1 to monitor temp and vibration on a spindle and i just cant seem to find the best way to do this. I would  like to use a cloud so I can monitor it off site and get a notification if the temp rises above a threshold. what would you recommend. I have tried the azur cloud i can get the device to connect but then in the classic app i can not get it to send any information. I have tried almost all firmware versions and just cant seem to crack this. Anything will help.
Thank you,
mƎALLEm
Your question is not clear. In which context? motor control application or what?
Please read How to write your question to maximize your chances to find a solution
PS: you've posted your request in a wrong forum.
I just want to be able to use the device mounted to a spindle and be able to monitor temp and vibration. The app is not great for doing this off site what are some options. Or ideas I have tried the app and it isn’t great for continuous monitoring or off site using a form of cloud. The app doesn’t work with IoT or at-least not efficiently.
