2023-02-15 8:27 AM
The iNEMO inertial module LSM6DSRX supports sensor synchronization S4S for Qualcomm. Sensor data sheet mentions following S4S registers without much detail.
Its not clear what values those S4S registers (TPH, CMD_CODE, DT_REG) should hold to function correctly.
Is there any application note describing how to configure S4S sensor synchronization on LSM6DSRX module.
Your help is much appreciated.
2023-02-23 9:02 AM
Hi @farid ,
Our devices support S4S which is a Qualcomm proprietary feature, which we therefore cannot document on ST apps. Please note that on ST datasheet is just reported state that it is supported. For a direct help, you should directly check with Qualcomm.
-Eleon
