Louis Loving
March 3, 2021
How do you configure an MIS2DH to generate an interrupt on INT1 when motion is detected?
  • March 3, 2021
  • 1 reply
  • 1314 views
I am trying to configure an MIS2DH to generate an interrupt on INT1 when the MISDH detects motion. I have code to configure the IIS2DLPC to do the same thing (it works) and I am trying to use that as a guide.
Here's the snippet of code where I am configuring the sensor based on the whoami register.
(I added the files that would be needed to actually answer the question.)
Best answer by Eleon BORLINI
Hi @Louis Loving​ ,
I would suggest you to use the IIS2DH Github repository (link) for a check on a MIS2DH-compatible device.
An example of base configuration is the following one (for example for the wake-up interrupt on INT1, iis2dh_wake_up.c:(
 /* High-pass filter enabled on interrupt activity 1 */
 iis2dh_high_pass_int_conf_set(&dev_ctx, IIS2DH_ON_INT1_GEN);
 /* Enable HP filter for wake-up event detection
 * Use this setting to remove gravity on data output
 iis2dh_high_pass_on_outputs_set(&dev_ctx, PROPERTY_ENABLE);
 /* Enable AOI1 on int1 pin */
 iis2dh_pin_int1_config_get(&dev_ctx, &ctrl_reg3);
 ctrl_reg3.i1_aoi1 = PROPERTY_ENABLE;
 iis2dh_pin_int1_config_set(&dev_ctx, &ctrl_reg3);
 /* Interrupt 1 pin latched */
 iis2dh_int1_pin_notification_mode_set(&dev_ctx, IIS2DH_INT1_LATCHED);
 /* Set full scale to 2 g */
 iis2dh_full_scale_set(&dev_ctx, IIS2DH_2g);
 /* Set interrupt threshold to 0x10 -> 250 mg */
 iis2dh_int1_gen_threshold_set(&dev_ctx, 0x10);
 /* Set no time duration */
 iis2dh_int1_gen_duration_set(&dev_ctx, 0);
 /* Dummy read to force the HP filter to current acceleration value. */
 iis2dh_filter_reference_get(&dev_ctx, &dummy);
 /* Configure wake-up interrupt event on all axis */
 iis2dh_int1_gen_conf_get(&dev_ctx, &int1_cfg);
 int1_cfg.zhie = PROPERTY_ENABLE;
 int1_cfg.yhie = PROPERTY_ENABLE;
 int1_cfg.xhie = PROPERTY_ENABLE;
 int1_cfg.aoi = PROPERTY_DISABLE;
 iis2dh_int1_gen_conf_set(&dev_ctx, &int1_cfg);
 /* Set device in HR mode */
 iis2dh_operating_mode_set(&dev_ctx, IIS2DH_HR_12bit);
 /* Set Output Data Rate to 100 Hz */
 iis2dh_data_rate_set(&dev_ctx, IIS2DH_ODR_100Hz);
Can you please check if you have correctly configured the sensor?
-Eleon
1 reply
Eleon BORLINI
Eleon BORLINIBest answer
Hi @Louis Loving​ ,
-Eleon
