how can i change the STEVAL-MKI109V3 VDDIO to 3.3 V or get the INT1_up or INT2_up signals with an 3.3V Level?
Options
‎2023-01-23 07:56 AM
Options
‎2023-01-23 12:28 PM
Welcome, @BSeeg​, to the community!
you can use the command *setvddio3.3 to set VDDIO=3.3V. This and all other commands are listed in UM2116.
Hope that helps?
/Peter
Options
‎2023-01-23 01:00 PM
Hello Peter
Is there a way to send comands in the unico Gui?
I tested The UART Interface and only the command
"*list"
did somthing
the Command
"*setdbMKI195V1" to select the LSM6DSRX Sensor i use got an
"inf Adapter nor supported" response
The conds *setvddio3.3 or *setvdda3.3 changed nothing nor got an response.
best regards Bene
