How calibrate 2 magnetic sensors concurrently with MotionMC library?
I would like to calibrate 2 magnetic sensors concurrently with MotionMC library. However, the functions from the library for MotionMC_Initialize, MotionMC_Update and MotionMC_GetCalParams do not need inputting an ID. If calibrate 2 sensors in the same time or power cycle, whether will HI_Bias[3] and SF_Matrix[3][3] coefficients be overwritten?
I do appreciate any idea for calibrating 2 magnetic sensors in same time with MotionMC library.
Qingshan
