Hi, we are working with LSM6DSL sensor, we need some info regarding the sensor. In the configuration sequence of sensor is it possible to change ODR with out turning OFF sensor an turning it ON back ?
JPale
Eleon BORLINI
​Hi @JPale​ , you can change the ODR without physically turning off the sensor (I mean Vdd OFF), but you have to pay attention to the data acquisition synchronization with different ODR. Considering the case you are running in continuous mode, consider for example p.38 of the AN5040. I basically suggest you to add waiting times when you switch the ODR. Regards
