Getting started with STEVAL-MIC007V1
‎2024-05-06 12:57 AM
Hi Everybody,
I am a beginner and I need some information to start using the following devices:
- Nucleo-F401RE
- X-Nucleo-Amicam1
- Steval-mic007v1.
I have currently downloaded the following material:
- X-cube-memsmic1
- Link007
- Link009
- Stm32cubeid.
Is it necessary to install additional software tools and/or embedded software?
Is it possible to get an initialization procedure or a video guide for the correct configuration of the devices for the use of the Steval-mic007v1 microphones?
Thanks for your help.
Best wishes,
Oscar
- Labels:
Microphones
‎2024-05-23 8:25 AM
Hello @OsBo
X-NUCLEO-AMICAM1 + STEVAL-MIC007V1 is natively supported in X-CUBE-MEMSMIC1 in conjunction with NUCLEO-L476RG and NUCLEO-L4R5ZI only.
By using the above-mentioned setup, you can go through the AMICAM1/Microphone_Streaming examples available in X-CUBE-MEMSMIC1. All the details are available in the User Manual.
Best regards
Simone
‎2024-05-23 8:25 AM
Hello @OsBo
Best regards
Simone
