JPlan.1
Visitor II
June 15, 2020
For the component ref. LSM6DSLTR from ST Microelectronics, I need the top-side component marking. I can not find it in the component datasheet. Could you please check? Thanks
  • June 15, 2020
  • 1 reply
  • 742 views
    1 reply
    Eleon BORLINI
    Hi @JPlan.1​ , the LSM6DSLTR top-side package marking is structured as described below (starting from the "pin 1" circular marking):
    XX --> the part number identifier (for example SF)
    Matrix code --> basically the device ID, it contains info about the chip wafer ID, the assy lot, the assy date
    YWW --> "Y" is the last number of the assembly year, while "WW" stands for the year week number. For example, "646" means week 46 of 2016.
