Can the machine learning cores or the state machines be used with user calibrated data?
Pasi MYLLYMAKI
Carlo LARGHI
MLC and FSM can't use natively user calibrated data, but, since the configuration of both MLC & FSM are loaded at the power-up of the device from an external host, the external host can modify/adapt the configuration to each single device based on user calibration data
Carlo LARGHI
