Can offset registers on LIS2MDL compensate strong magnetic field?
MHo
I'm working on a prototype device. It is very compact, battery powered and has a motor inside. I want to know if the offset can be set (during production) to compensate a very strong magnetic field and still be able to detect earth magnetic field for heading. Is there any other way/sensor can achieve this?
Thank you,
Min-Ching Ho
10 REPLIES 10
MHo
Yes. I was able to make it work.
