Bandwidth vs ODR
I would like to know what is the difference between bandwidth and ODR. I tough that just the analog accelerometers have bandwidth and the digital ones have ODR. For example, IIS3DWB can go up to 5kHz bandwidth and 26.7kHz ODR. Does this means that internally, the accelerometer takes up to 5kHz samples, but it can output them at 26.7kHz rate? If yes, it means that I will have duplicate data if the ODR is greater than 5kHz?
Gabriel
