asm330lhhx scale factor for each x, y, z axis
BPEngineer
For the asm330lhhx device, when does the scale value change and get set?  I am trying to determine if the scale factor needs to be checked only once at power up or continually while reading the raw x, y, and z values for both the gyro and the accelerometer.
In Linux Terminal, the scale and raw values show up as the following for the x component of the gyro:
in_anglvel_x_scale
in_anglvel_x_raw
I plan to read the scale once and the raw value continuously.  But if the scale value changes, then I need to read both continuously.  Please confirm how they work as the datasheet was not clear on this.
Thank you!
BPEngineer
I see now that you can set the scale value yourself.  Please close this issue.
BPEngineer
