2025-12-14 6:20 AM
the values of my accelerometer axes are affected by temperature changes and require calibration at each temperature.
What method should be used for compensation? How can Bias Drift and Scale Factor Drift be determined each time the temperature changes?
2025-12-15 2:44 AM
You haven't said what accelerometer you are using.
How to write your question to maximize your chances to find a solution
There should be temperature data in the datasheet?
2025-12-16 1:50 AM
2025-12-16 2:55 AM
So did you read the datasheet to find the temperature-related specification ?
It is your job as designer to study the datasheet ...
2025-12-16 3:07 AM
Yes, I have studied it, but I am looking for an appropriate algorithm to compensate for temperature when using bias and scale coefficients.
2025-12-16 3:12 AM - edited 2025-12-16 3:48 AM
Your attached datasheet doesn't seem to work.
Here's the ST Product Page: https://www.st.com/en/mems-and-sensors/lis331dlh.html
The temperature variations are specified in Table 3 of the datasheet:
https://www.st.com/resource/en/datasheet/lis331dlh.pdf#page=9
