Algorithm to store Gyroscope and Accelerometer values with associated Timestamps from FIFO when the compression is on.
BDiva.1
Need help in storing sequential gyroscope and accelerometer samples with associated timestamps in array when the FIFO compression is turned on. Ideally this should be the following entries:
Timestamp1, AccelerometerX1, AccelerometerY1, AccelerometerY1, GyroscopeX1, GyroscopeY1, GyroscopeZ1
Timestamp2, AccelerometerX2, AccelerometerY2, AccelerometerY2, GyroscopeX2, GyroscopeY2, GyroscopeZ2
TimestampN, AccelerometerXN, AccelerometerYN, AccelerometerYN, GyroscopeXN, GyroscopeYN, GyroscopeZN.
The code should be in C (no lists), the IMU is LSM6DSO. Thanks!
Eleon BORLINI
Hi @BDiva.1​ ,
you can find a C sample code for FIFO when the compression is on for the LSM6DSO on Github --> lsm6dso_compressed_fifo.c
You can find the general example folder for this device at this link.
Let me please know if this can be helpful for your application.
-Eleon
Eleon BORLINI
Hi @BDiva.1​ ,
-Eleon
