Accelerometer without gravity
dsath.1
We are trying to get Accelerometer without gravity
kindly let us know if there are any possible way to get the same.
Dwithi
4 REPLIES 4
raptorhal2
Lead
Put it on the Space Station.
I presume you mean eliminate the vertical G value. Subtract one G from the vertical reading. If the accelerometer rotates, use a version with a gyro output also and do the vector arithmetic to subtract the effect of gravity.
Cheers, Hal
kindly let us know with the calculation part.
raptorhal2
Lead
This is your project. Do an Internet search on "axis rotation" and "axis transformation".
Cheers, Hal
CZorg.1
enable the high pass filter on the chip, it will remove the dc offset (gravity)
