2022-06-28 07:10 PM
I am using the BlueNRG-2 alone as an MCU.
I want to import X-Cube-AI into the BlueNRG-2.
However, there isn't the 'BlueNRG-2' name list in the MCU selection in the STM32CubeMX.
Is it possible to import the X-Cube-AI into the BlueNRG-2?
2022-06-29 12:26 AM
X-Cube-AI is only supported on STM32 MCUs.
The library has never been tested and won't work as is on the CortexM0 of the BlueNRG-2.
Daniel
2022-06-29 12:26 AM
Daniel
2022-06-29 08:41 PM
Do you have any plan for BlueNRG-2?
