Write SD card using bluenrg 332ac
‎2024-10-14 4:53 PM
I am trying to write the IQ data to the SD card (i.e., write the received CTE pkt to the SD card). However, I found that Bluenrg-332ac has a cortex M0 core, which may not be able to drive an SD card. Is it possible to use this cortex M0 core for SD card writing?
Thanks,
Jason
- Labels:
BLE Mesh
‎2024-10-15 6:27 AM
Sure, a Cortex-M0 can access an SD-Card - even 8051s, AVRs, et al can do it!
eg,
‎2024-10-15 6:27 AM
eg,
‎2024-10-15 9:18 AM
Thanks Andrew! I also wanna ask can I use cubeMX to build programs for the Bluenrg-332ac chip?
‎2024-10-15 9:31 AM
@JasonYang wrote:can I use cubeMX to build programs for the Bluenrg-332ac chip?
"The BlueNRG-LP and BlueNRG-LPS lines have been rebranded as STM32WB06/07 and STM32WB05, now seamlessly integrated into the STM32Cube ecosystem"
https://www.facebook.com/watch/?v=1579234726355456
https://www.st.com/en/embedded-software/stsw-lp-profiles.html
